Unusual PL400
Sunnbobb
Mount Vernon, WA
Bikes, baseball and big amps.
I picked up a PL400 that looked pretty mint. I noticed the outputs had been changed to banana plug compatible jacks, and assumed there had been some work done to the unit. When I finally got to inspect it closely, i was kinda amazed. I've built around 10 of these so far, and every one had some previous work, some good, some bad. What I found in this one was nothing I'd ever seen.
First off, it had a nicely mounted on/off switch and power light, properly snubbed. it also had a quality microswitch to turn the meter lights on and off.
But that was nothing compared to what was inside. Not only had the boards been rebuilt, but this thing was sporting 4, yes 4, extra filter caps. It also is fitted with DTS402 transistors, something I had never seen.
I checked the fuses and hey were fine, the main fuse having been replaced with a 10A rather than the standard 8A.
I ran it up on the dim bulb and it fired up perfectly. After checking for anything weird, I went ahead and measured the DC offset. .28 mv on one channel and .30 on the other. The bias was also spot on. The main filer caps are running 9V, and the four add on caps running right around 35V on average.
All the work done on the inside was very professional. I bought this planning to drop an extra WOPL board and Audio speaker relay that I have, but honestly. I might just leave it alone.
I think I'll hook it up to the osc and see what sort of power this might be putting out.
Anyone ever see something like this?
That thing is tricked out! Boutique caps n all!
Blows my mind all the goodies and how well they were installed. I was hoping it might have been built by someone around here. And the use of those transisters... first time I have every seen them, perhaps a new alternative for the tired old PL's and and alternative to the MJ 96's?
Not a chance...
Just no comparison...
DTS402
Vceo = 400V
Collector current max 3.5A
Power dissipation max 100W
Ft = 2.0 Mhz
Hfe = 10 @ 3A
SOA unrated
Ignition coil transistor
MJ21196
Vceo = 250V
Collector current max 16A
Power dissipation max 250W
Ft = 4.0 Mhz
Hfe = 25 @ 8A
SOA is rated
Audio transistor
DTS402
Vceo = 400V
Ft = 2.0 Mhz
Hfe = 10 @ 3A
SOA unrated
MJ21196
Vceo = 250V
Ft = 4.0 Mhz
Hfe = 25 @ 8A
SOA is rated
Audio transistor
LOL, I thought you were talking about the person who built this being on the forum. But, that is some great information boss. Looks like I have some spares for my 76 jaguar.. hahaha
Where is the fourth filter cap, and why are the unused solder lugs 2mm away from a flexible aluminum front panel? The fuse change was standard practice when a 400 is used for PA. SOA is a function of both current and collector voltage, so maybe the DTS 402 is pretty good with high inductive or capacitive loads...electrostats would not need a lot of current but they would need that extra SOA area for the extreme phase angle in the treble.
THe 4th cap is mounted on the inside of the side wall. The aluminum front plate has an insulation layer applied to it. You may be on to something there. The unit is in near mint condition, perhaps it was used as a disco unit.. lol
