- May 14, 2014
- Southwest Kootenays BC
I duplicated, or nearly duplicated, what I did to a Toshiba SC335 power amp on a second one. With the first I replaced all the electrolytics and followed a recommendation to replace 2 pairs of transistors with 2 matched pairs of new ones. Since I have nothing but a DMM, I read of a down & dirty measuring technique to check transistors which was what I followed to match them.
The end result with the first amp was a DC offset of about 12mv on one channel 13mv on the other.
With the second amp I did not replace the large power supply filter caps. After adlusting bias to ~ 10mv as was recommended, the DC offset is about 25mv & 12mv.
I understand that this is considered to be within acceptable limits but I am curious as to why one side is double that of the other?
I can increase / decrease the bias to equalize offset but that means the idle currents are unequal.
Could those filter caps, old as they are affect DC offset?
This is probably no big deal as both offsets seem to be low enough but it bugs me that they are not closer.
