ThomOfYorke
- Jun 18, 2024
I'm a member on many audio forums, but I've found this place to be one of the most straight-shooting. Some places seem to be filled with people who cook all their meals with snake oil, and others are so obsessed with measurements and specs that they appear to think spending more than $50 for anything is for suckers. I've got my own list of audio-related things I'm pretty convinced are snake oil, but there's a few things where I've not settled the question one way or another.
Anyway, I want to ask those more technically inclined than I am: can disc transports and streamers make any appreciable difference to sound quality? I'm talking about dedicated transports and streamers without internal DACs.
I have a transport and a streamer each going into an external DAC, but I haven't spent big bucks on them. I have the Cambridge Audio CXN v2 streamer and Cambridge Audio CXC transport. These were each around 1k when I bought them new a few years ago.
The reason I ask this is because I've noticed transports and streamers seem to split fairly hard into two camps: those around a few hundred to ~1k, and then those anywhere from 5-20k! I'm under the impression that a transport simply spins a disc at the correct and constant speed, reads the disc and outputs the data to a DAC, and a streamer sends the data to a DAC. So long as each is designed properly and doing its job, wouldn't one transport/streamer be as good as another in terms of sound quality?
On other forums, I'm swarmed by people who insist that each of these components makes an appreciable difference to the sound quality, though usually this is supported by anecdotes about them 'hearing two streamers in a shop and the more expensive sounded better'.
Is there anything that can justify a 5-20k streamer or transport that isn't related to the 'bling' factor (expensive, heavy chassis, huge touch screen interface, brand prestige, etc.)? Am I missing something as regards how these components operate or what they do?
This is a genuine question. I'm not a tech so I'm really trying to figure out whether these are components I should want to upgrade at some point in the future, or if I should pretty much always prioritize other component upgrades over these (speakers, subs, (pre)amps, sources).
Thanks in advance for the clarification!
