Transistor circuit help needed
John482
I have an amp on my vintage Telefunken r2r that has lost one channel due to shorted output transistor. I was checking it out and noticed that I have portion of the circuit showing 6.7k across a 6.7k resistor, the functioning channel shows about 800 ohms across it's 6.7k resistor. Both resistors out of circuit show 6.7k. Ideas?
You have all the test point voltages- check all of those to help narrow the search.
It appears that each resistor is spanned by the B-E junction of T302 or T402 depending on the channel. That B-E junction could be what is measuring 800 ohms on the good channel. Since the B-E junction is polarity sensitive, have you measured the resistor, in circuit, using both polarity directions of your DMM?
John482
The good channel resistor is the one at 6.8k, r306 is measuring 800 ohms. I stated that wrong, sorry. R406 in the good amp is 6.8k. I measured both out of circuit and both resistors are spot on.
