Time Delay Audibility
Interesting article......
[TABLE]
[TR]
[TD]www.ethanwiner.com - since 1997[/TD]
[/TR]
[TR]
[TD]
[TABLE]
[TR]
[TD]Home & Contact[/TD]
[TD]Audio & Music Bio[/TD]
[TD]Programming[/TD]
[TD]Wisdoms & Quotes[/TD]
[TD]Funny Names[/TD]
[/TR]
[TR]
[TD]Magazine Articles[/TD]
[TD]Cello Page[/TD]
[TD]Ethan's Tunes[/TD]
[TD]Oxymorons[/TD]
[TD]Family Photos[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
Some Experiments With Time
On the audibility of phase shiftby David Clark[TABLE="width: 70%"]
[TR]
[TD]This article was written by David Clark in 1981 for the Winter 1983 issue of the Syn-Aud-Con newsletter. It is reprinted here with David's kind permission because I believe it is still very relevant today.[/TD]
[/TR]
[/TABLE]
[HR][/HR][Syn-Aud-Con newsletter] Editor's Note: David L. Clark, manufacturer of the ABX Comparator, has taken the leap into a "highly charged" area. We admire his thoroughness and are pleased to publish his comments on the subject. Both David and Syn-Aud-Con would be tremendously pleased to hear any comments Syn-Aud-Con graduates have to offer. In the meantime, we appreciate David's having fired the opening gun.
[TR]
[TD]Three experiments were performed which confirm the audibility of time offset in loudspeaker drivers but indicate that this audibility is due only to the frequency response aberrations resulting from the time offset. Implications of these results are discussed.[/TD]
[/TR]
[/TABLE]
INTRODUCTION
On and off for the past couple of years I have been experimenting with the effects of intentional time and frequency response aberrations. My experiments have perhaps been unique in that they have been performed using normal home or control room environments with hearing constituting the instrumentation. The hearing could truly be called instrumentation because listening was done double-blind and opinions were not used. Listeners were simply asked to perform a task or to hear a difference. I feel that studies of this type are more relevant to knowledge of sound reproduction than clinical tests or opinions derived from "open" evaluations.
For the sake of clarity and simplicity, I will describe the experiments as though they proceeded orderly as if following some master plan. The experiments in reality took many "dead end" paths and were guided by hunches, finances, time, and available equipment. I often wonder if experiments that seem to have been perfectly orchestrated from the beginning might not have followed up a hunch that would have led to even more interesting results.
SPEAKER ALIGNMENT AUDIBILITY
The purpose of the first experiment was to determine people's ability to hear time offset of a woofer and tweeter. The test setup is shown in Figure 1. Left and right channels were treated identically. The signal from either channel first is divided into high-pass and low-pass by a 6 dB / octave unity sum crossover at 1 KHz. A high quality crystal time base digital time delay unit with delay either 1, 2, 3, or 4 milliseconds is inserted in the high-pass path. An analog time delay unit with delay adjustable via an uncalibrated 10-turn control from 0.3 to 10 milliseconds is inserted in the low-pass path. The high- and low-pass signals are then amplified and fed to two identical stacked full range speakers (Phillips AD5061s). Thus in the full stereo system we have four identical speakers. Each side has the lower speaker assigned to be the woofer and the upper assigned to be the tweeter.
[TABLE]
[TR]
[TD]
[/TD]
[/TR]
[TR]
[TD]Figure 1: Experimental setup to determine listener's ability to match time delays. Listener has adjusted the uncalibrated pot for "most natural blend" of woofer and tweeter.[/TD]
[/TR]
[/TABLE]
Using music of the listener's choice, the listener is asked to find the setting of the 10-turn control which produces the most natural blend of woofer and tweeter. Technically, the task is to match the acoustic position of the woofer and tweeter by matching the time delays.
Since the listener does not know the setting of the digital delay or the relationship between the analog unit's control rotation and its delay, (it is quite non-linear), the only clue to proper alignment is sound. (The knob was even loosened from the shaft and rotated between trials.) Since no one knows the correct setting in advance the experiment is double-blind. After the listener is satisfied with the setting, a frequency counter is connected to measure the clock frequency of the analog delay. From this the actual delay is calculated.
Despite the possibility of "digital effects," the modest quality of the speakers, and the fact that the listeners were in effect being tested, every one of approximately 12 participants was able to match the time delays to within +/- 40 microseconds (about 1/2 inch). This finding confirms the clams of those who espouse the virtues of arrival time compensated loudspeakers.
After testing the listeners were asked how they found the correct setting. In general, the replies were that for extreme settings of the control, the sound would come from either the woofer or tweeter speaker. Somewhere in the transition range a "swooshing" or "phasing" effect was heard. The final position of the control was the one that "tuned out" the phasing or swooshing.
Other than the obvious implication of the Haas effect for extreme settings, no one spoke of sensing "time smear" or any quality except the swooshing which could be considered to be either a time or frequency response effect. Since a time offset would obviously cause comb filtering over a wide range due to the 6 dB / octave crossover, I was curious to know if it was time or frequency response that was responsible for the listeners' ability to align the speakers in the experiment.
FREQUENCY RESPONSE AUDIBILITY
Figure 2 is a graph of various bandwidths of minimum phase response aberrations or level mismatches which have proven to be just inaudible in double-blind testing. For most of this data the subject was myself. Spot checks showed that I am fairly typical in my ability, but additional testing would only serve to lower these curves. As they stand, they indicate that very small ripples in the frequency response such as those generated by a slight time offset could be audible. The on-axis frequency response could also change because of the vertical polar pattern shifts resulting from time delay combined with the vertical displacement of the drivers in the test. Lastly, the act of tuning to an upper swoosh threshold then down to the lower swoosh threshold then finally centering the knob between the extremes could result in enhanced "setability." In summary, frequency response effects alone could account for the remarkable ability to match acoustic centers.
[TABLE]
[TR]
[TD]
[/TD]
[/TR]
[TR]
[TD]Figure 2: Amplitude of the frequency response matching errors of various bandwidths which should [/TD]
[/TR]
[/TABLE]
The rest...............[TABLE]
[TR]
[TD]Figure 2: Amplitude of the frequency response matching errors of various bandwidths which should not be exceeded in an ABX test. Music source material is assumed. Unusual sources may require tighter matching.[/TD]
[/TR]
[/TABLE]
TIME OFFSET AUDIBILITY
Now that frequency response audibility independent of time effects had been studied, I desired to test the time effects without any accompanying frequency response aberrations. The circuit of Figure 3 is an all-pass filter. It has a flat frequency response but gradually changes phase shift from near zero degrees at low frequencies to -180 degrees at high frequencies. Fifteen of these circuits were wired in series for each channel with taps at intermediate stages. While generating -2700 degrees of phase shift over the audio band, the series string of fifteen filters delays low frequencies nearly 7 milliseconds in time. This is approximately 1,000 times as much delay as the spread of listeners' matching errors in the first experiment. In this instance, however, there is no accompanying frequency response error.
[TABLE]
[TR]
[TD]
[/TD]
[/TR]
[TR]
[TD]Figure 3: Characteristics of the all-pass filter used to study the audibility of time offset without frequency response aberrations.[/TD]
[/TR]
[/TABLE]
Hundreds of unsuccessful attempts have been made by listeners to distinguish the full delay from a wire bypass. Listeners have been of all skill levels using a variety of high-quality systems including arrival time compensated speakers and headphones. On music or speech, no one has been able to hear a difference in a double-blind test. "Hearing a difference" to me means being able to identify which is which frequently enough to qualify for at least a 95 percent confidence level (only 5 percent chance results were due to lucky guesses). This requires 12 correct out of 16 tries, for instance.
Somebody should be able to hear this delay given the right program material. (I suggest percussion or raspy male voice.) A pure "tick" can easily be identified as having been passed through the full delay by a "TEE-OOM" (say it fast) sound. Look at the perspective however: 1,000 times the delay of experiment 1 is required. A hypothetical loudspeaker with this "time alignment" would have the woofer over seven feet behind the tweeter but somehow retaining a smooth frequency response. Given that the response alone can explain time offset audibility and time delay alone cannot explain this audibility it seems inescapable to conclude that arrival time compensation by itself has no audible value.
DISCUSSION
If I were to design a speaker system for a very flat response, I would probably use arrival time compensation because it would likely be the easiest way to get a flat frequency response. A mistimed speaker with equally flat response presumably could exist, however. All other things being equal, within reason, I would expect the two to sound identical.
I see the importance of these studies as relating to using the new Crown TEF analyzer. I have seen inexperienced users of a hand-held 1/3 octave real time analyzer overloaded by data from a stroll around the sound system. The potential of the TEF analyzer to produce data overload is enormous. We can see with equal ease the energy-time response or the energy-frequency response. It would be all too possible to sacrifice first arrival frequency response to get an aligned first arrival time response. From my experiments, if a compromise were necessary, I would make any reasonable sacrifice in timing to get a flat frequency response.
Maximum
Maximum benefit from TEF analysis will only be realized when we can place its measurement capabilities in a hierarchy of human values.
So, could that explain why the K's sound so good?? The low frequencies pass through what could be called a maze before being blated out between the wall and the inner baffle outside wall. While the mids and higs are radiated directly to you, line of sight stuff. If low frequencies arrive later, given an equal transmission spot then the K's design should exacerbate this difference.......and yet I have heard only one speaker which I would listen to regularly other than the K's, and time compensated features were a major selling point---the Ohm Model F's. Imagine a traffic cone, the upper third of the cone being titanium, the middle third aluminum, the bottom third a fiber compound typical of woofer material. That's a Model F. Does the brain compensate for the time delay if the reproduction has a fairly flat response? And if it does, WHY? Is hearing that manipulateable by the grey matter to fill out missing parts to give a more complete aural experience? Why would THAT be important? Is it something in our evolution that was a survival enhancement? Ponderous, very ponderous.....
Say the neighborhood is running amok with your basic raptor style dinosaur. After some exposure to several midsections of some of the prehistoric men being incised by the jaws of said raptors, and just preceding this life ending midsection crunch, there's a snap of the jaws that's very unique, kinda like we smack our lips knowing something VERY tasty is about to be caught. In the mass hysteria that ensues, not all midsection crunches are heard, but every preceding "snap" is, does the mind fill in the blank as a survival incentive? One would think the raptors would miss occasionally, but the odds are they won't and prehistoric man can't afford to be of two minds when hearing the "snap" so the other sound is "heard" to act as an incentive to get the F*&^ outta there??
Joe that statement was part of the article, I take no credit for that one.
It was a combination Scott....
