- Mar 18, 2013
- Coventry, CT
- Fondler errrr... fan of all Nav's avatars
I have been diagnosed with Fuchs Corneal Dystrophy so I am getting money together to cover my copay for office visits and very near future corneal surgery
Asking $160 shipped/insured in the US via FedEX, I doubt you can find another in similar barely used clean condition. This amp requires a preamp to drive it OR a CD player w/ a volume control. This amp came from AK member Edroom via a trade with another AK member
PayPal (F/F preferred or add 3% for the fee) to: topeliminator@earthlink.net
Please post SOLD and PM me here with your US shipping info
EDIT: Click on any image, they open HUGE for fine detail/description. On Phoenix, right click properties of any image and paste into another browser and the images are poster size
Thanks! Ron
Please note that this I consider a mini WOPL, it also shares the 1000 damping factor of the PL amps. This amp is no joke for short money. In fact, the specs are very similar, just less power output but this amp will easily shake your house
Description
Unprecedented dynamic headroom, vanishing distortion and precision control of speaker cone excursion. These are some of the rewards of the new technology to be found in the Basic M1.
A startlingly simple design concept translates into a much sought after goal of higher power handling ability combined with low distortion and outstanding tonal quality. A patented Kenwood technology, the DLD power circuit brings together the best features of a top quality medium power amplifier and a high power amplifier, totally sidetracking their disadvantages. Thus, you can get the enormous power needed to amplify the most dynamic music signal peaks.
Simultaneously, you can hear the kind of smooth, evenly balanced tonal quality extending throughout the audible range you would normally expect only from a first rate medium power amplifier. There are no size, weight, heat or thermal instability problems. Dynamic peaks are handled easily and are so clearly perceptible they will satisfy the most hypercritical listener.
Highly reactive speaker loads and crest value music signals that exceed rated output are taken fully in stride by the Basic M1. This amplifier can comfortably handle the highest dynamic peaks, even at rated listening levels, and can operate fully with speaker impedances that fall as low as 2 ohms.
The amplifier is designed for a frequency response accurate to within +-3dB from 1 Hz to 300kHz, ensuring that all signals falling within the audible range are reproduced perfectly.
Specifications
Power output: 105 watts per channel into 8Ω (stereo)
Frequency response: 1Hz to 300kHz
Total harmonic distortion: 0.005%
Damping factor: 1000
Input sensitivity: 1V
Signal to noise ratio: 120dB
Speaker load impedance: 4Ω to 16Ω
Dimensions: 440 x 112 x 324mm
Weight: 9.1kg
Thanks! Ron
Description
Specifications
Weight: 9.1kg
![](http://i.imgur.com/lb8ICZq.jpg)
![](http://i.imgur.com/7ocdwIA.jpg)
![](http://i.imgur.com/mYq0eNy.jpg)
![](http://i.imgur.com/drFFS4H.jpg)
