Third Hand
Nick Danger
Bought a drill press a little while ago and felt the compulsion to make holes in things:
The gooseneck things we use to move coolant on lathes so they stay where ya point it...you can buy all kinds of tips for em..,..
You can snap em apart at any of the joints and make em longer or shorter or what ever..
Never thought of using them like that though, gonna have to get me some....don't know who makes em though...
Flexible tubing I picked up here. I used some generic banana clips and with a little bending with some jewels pliers, they fit nice and snug in the nozzle ends. Used the press to drill holes through nozzles and clips so I could run some wiring through both to keep them together.
Idea was an Instructable I came across a while ago.
The tubing I used is a slightly different size than the Loc- Line brand and is not compatible with their accessories.
If you have the strength of a mountain gorilla! These suckers fit SNUGLY. The Loc- Line brand actually sells a tool for assembly/ disassembly.
That's ok Doug, I can get some up here...
That is a cool application for the flex tubing - we use these for our CNC machine and I would have never thought of using them for something else. I'm thinking Doug that you can use two of those extra hands to hold a couple of components while you're soldering and the third could hold a spliff. :smokin:
Keep the blood pressure down as I melt holes into my PCB.......
3rd Hand putting in time today
Normally I would allow my solder sucker to hang off the table and bounce on my leg to let me know where it was located:
Well, that's no fun.
Was glad to have it to hold a component and magnifying glass so I could snap a picture:
