The Beast
Tony: That looks like something very un-stock for a computer. Did you custom build it? Would I need something that fast and multi-tasking to post rapid fire responses on the forum?
BlazeES
No!
But to game, convert/edit audio and video, it kills.
Custom built to burn down the house when it needs to,
and minimize the wattage for the daily stuff. It's my
first ever liquid cooled rig. :cool:
It cold boots to the desktop password entry in about 15 seconds
and comes out of sleep pretty much instantly.
BlazeES
Will you be jumping to the Xeon Haswell when it becomes available?
Don't plan on doing another platform shift for another 5 years. Xeon is geared for servers anyhow and I don't serve off this rig.
The reason I made the move now was because components have been trending towards stupid low prices if you time the purchase right,
my previous machine was just over 5 years old and the CMOS was going flaky on me
AND
this new 4790K processor is stock 4.00 GHz with Intel Turbo Boost to 4.4 with real-time throttling. I ticked up the overclock to a max limit of 4.6
That's enough horse power for my needs for the long term and I like nice even numbers for the base clock. :???: It has taken Intel forever to get a
multi-core processor to base @ 4 GHz. To give you an example of an important gain, on my old Gulftown rig - which even had 6 cores -
it would take about an hour and a half to convert my entire digital music library (approx 4500 songs) from various lossless formats to variable bit 160 kb/s
for my phone or usb stick (car tunes). This new rig does the same in about 40 minutes.
I expect at least a 25 - 30% reduction in encode time for raw video too.
The other cool thing about these 4th Gen processors and their supporting chip-sets is that they really throttle down well below the stock *active*, rated speed when your
doing mundane crap like surfing, word processing or viewing pictures and playing music. Mine drops down to 800 MHz and the entire rig goes into power sipping mode.
My last rig was nearly a space heater on average and definitely a blow torch when I gamed or encoded ...
So my biggest goals were,
cut way back on the number of power sucking hard drives,
get faster processing power for the big "jobs" & power efficiency for the rest of the time,
and get hardware that Win 8.1 can fully exploit.
Within the next 5 years, DDR 4, USB 3.1, 14 nm processors and SATA express will be mainstream at affordable prices.
I'll be upgrading to a new build then.
Did you get my PM about the keyboard, etc?
Dark boards are hard on my eyes these daze.
BlazeES
Back to The Beast:
This is what the new tech can do.
New motherboards have more capable hard drive buses and when you marry a small solid state drive, used as an acceleration cache, to a drive (or in my case, two drives in a striped pair...), you get read speeds like this:
The first set of measurements show the net effect on speeds that the Intel acceleration has when tested on the hard drive partitions,
the second set of numbers is when you test directly on the solid state drive. The theoretical limit on modern SATA buses right now
(SATA III) is 600 MB/sec but the real-world peaks are typically capped at 550 MB/sec. Without acceleration, the data flow would go no
faster than about 150 MB/sec in single mode, or around 270 - 280 MB/sec as a striped raid pair. Needless to say, caching screams fast data.
Blaze Tip of the Day:
The biggest road-block standing the in the way of most computers (of the last 5 or 6 years) is hard drive performance.
Maximizing hard drive throughput by way of reducing data bottle necks will transform a sluggish computer into something
that feels damn near new. Even on a Vista machine ...
