- Jun 12, 2010
- OZONE ALLEY MARS (Visitor)
- Wasted Days and Wasted Nights
Stuwee asked what I use.I have some mean chemicals that would melt every plastic it touched. So I'm going the Iso route.
1st I trim an acid brush short to make it stiffer. Worked good. One pulley clean. Motor pulley was sticky. So I turned the deck on and hit play. Just hold the brush to remove the residue. Let the motor do the work.
When I get the belts I change one at a time. Thus no confusion.
Larry
PS Will Continue.
Larry
PS Will Continue.
