Started my build, have issues
dave5701
I have PL400. Need some brain help here. Bought enough TO-3's to change out one side of amp, got cap upgrade, got speaker protect. All from WO and Wattsabundant. First step was to check TO-3s to stop fuse from blowing. Went through every one, used Fluke 77 in diode mode to check em. Found two shorted. I replaced all TO-3's on one channel and used leftovers to replace two bad ones. Fuse still blows. Could be more TO-3s went bad in the repair process? Can I pull all to-3's out and see if fuse blows. If fuse does not blow, can I put in a couple at a time to see which one causes problem? Another approach?? I would like to get the old gal powered up without fuse issues then tackle the caps then speaker. Want some stability before causing any issues I might make.
AngrySailor
---not quite right
Are you sure your power supply caps aren’t causing the fuse to blow? Dim bulb tester bright?
dave5701
Thanks to all you guys for the help. I built a DBT and had to come up with my own mods for that. I did not have a 100w bulb (Wally World is 100% LED friendly so Dollar General helped me out) so I bought cheap lamp bulb replacement sockets and had an old school "Y" for two bulbs in one socket and used 3 40w appliance bulbs in parallel. Finally got all TO-3's in WITHOUT blowing fuses. Did the cap change out, that was much easier than I thought AND it was obvious the difference they made proven by the DBT. The original caps would power up in 2-3 seconds (came on bright then dimmed down to nothing), but new caps took 4-5 seconds to dim out. Next step is speaker protection and I have all the stuff for that. This is truly an interesting project.
AngrySailor
---not quite right
Not blowing fuses without the dim bulb now? What’s your bias and offset readings? This is all Stock PL right?
dave5701
Yes stock PL. not sure on bias but I think by offset you mean what DC voltage do I see at output? DC at output is .003VDC on each channel.
AngrySailor
---not quite right
Search the site here for the pl-400 manual and service manual. Not sure I can phone post it. Also read Joe’s documents/instructions (they’re the eff’n PL bible...). Bias is measured across the B-E on the outputs. 350mV is about what you’re after. Too much bias will turn on the +\- rails at the same time and could be the cause of your “short”. If it runs hot idle good bet there’s a bias issue...
dave5701
Hmmm. Ok. I will look into that. I have some service manuals and other stuff I found and my memory is crap but I think I remember something like that somewhere.
