Well here I am,
I have been pretty busy working at home. The Radio job took a hike last week so now I am working full time in the bench area and the computer area as two of my computer mysteriously went down with Trojans just after I put Comcast on line. After two days of fooling around the computers are back up and running.
As to the V8000, I have seen either none of them or maybe just one. These were marketed after I left the Chicago Factory Service facility for the last time. Not the Teac owned one but the one that Denny Camp bought from them and ran for a number or years.
I would be glad to look at it to see if the problem could be resolved. The heat has to be coming from somewhere. In that, if it was excessive I would work to make it less even if
modification was needed. Things can get warm but a bad design or broken circuit will allow things to get too hot. In electronics it is always wise to keep things as close to room temp as possible. If you are looking for a fast experience answer I would consult Russ Bachmann at New Jersey Factory Service as it is likely he has seen more of these than I.
As of the job end about Tuesday last week, repairs have been coming in like hot cakes and I am going to have trouble keeping up. I don't work an 8 hour day at home it is
from 8 AM or earlier to Midnight with distractions like checking E mail and taking in units
as they may present themselves.
I would make sure the unit is working on 120 Vac setting and then determine where the heat is coming from- maybe a shorted solenoid driver. Could be a power supply regulator is shorted. I would have to investigate. Heat can cause havoc with parts but the items of concern are that the pinch roller is not skewing the tape- this causes longitudinal damage to the tapes and if the take-up was to stop and the tape pile up at the pinch roller- this causes take eats that are the most serious. A torque gauge on the unit will tell a story even before a malfunction is had. That is why it is important to keep the take-up mechanism in good shape in that some people ignore excessive torque or allow for weak values. Both are indications that trouble is on it's way.
In the future- if I don't answer quickly feel free to send directly to my new E mail
address which is
skywavebe@comcast.net
Sorry for the delay
