Setting the Bias on the PL14_20 Board
Initial setting of the amplifier bias is a very simple procedure with the White Oak Audio PL14_20 board assembly. The bias is not all that critical and will drift around somewhat as the amp warms up. Do not be concerned that the setting is rock solid. It is a feedback control system using Q6 as a thermal sensor in the board circuit. As the amp warms up it is natural to have some movement in the bias voltage setting by design. The final bias setting you are working to achieve is between 0.300V and 0.400V. Most Phase Linear users find a setting near 0.350 – 0.380V close to ideal.
- Ensure the amp is powered off.
- All measurements will be taken with NO inputs connected to any source and NO outputs connected to any speakers.
- Open the top cover to expose the top edge of the PL14_20 PCB. Be careful not to drop any hardware down into the amplifier enclosure.
- Turn both bias pots located on the top edge of the board assembly fully counter-clockwise (minimum bias setting). These pots are labeled Left Bias Adjust and Right Bias Adjust.
- Attach your DVM positive test clip to the left channel bias setting test point. It is located in the upper left corner of the PL14_20 PCB and is marked Bias - L.
- Attach your DVM negative test clip to the LEFT channel WHITE speaker output binding post.
- Power up the amp and allow it to warm up and stabilize for approximately 5 minutes
- Adjust the Left Bias Adjust pot to achieve a bias setting between 0.300 and 0.400V. Most Phase Linear users find a setting near 0.350 – 0.380V close to ideal.
- Carefully move and attach your DVM positive test clip to the right channel bias setting test point. It is located in the upper center of the PL14_20 PCB and is marked Bias - R. This test point is located just to the right of the upper mounting nut holding the board into the chassis.
- Attach your DVM negative test clip to the RIGHT channel RED speaker output binding post.
- Adjust the Right Bias Adjust pot to achieve a bias setting between 0.300 and 0.400V. Most Phase Linear users find a setting near 0.350 – 0.380V close to ideal.
- Power down the amp.
- Remove test leads from the DVM.
- Reinstall the amplifier top cover. Be careful not to drop any hardware down into the amplifier enclosure.
- Bias setting complete.
