Servicing the door of a Pioneer CT-F-500 need SM/advice/diag
I have a cracked part, the right side arm left when you remove the door frame. The sides are separated and independent of each other with the left arm moving the entire thing.
Re: Servicing the door of a Pioneer CT-F-500 need SM/advice/
Will one off a CTF4242 work?
I've got THREE CT-F500's. One is a parts unit and the third needs belts. The one I'm fixing has good belts. I have the replacement part but need to figure out removing the old and install the replacement.
I gathered that but I've been hoping to find an exploded diagram.
I'll look on Hifiengine again, been a while form that one.
WHat about AK's pioneer database or Siguards?
I looked through the main Pioneer database, still looking.
I looked sometime last year as well as I had forgotten about the broken door after looking to fix it for myself. Still, if I belt the other whole deck I too can have one.
