- May 14, 2014
- Southwest Kootenays BC
Does anyone know much about selenium rectifiers?
Last fall, I mentioned in a different thread about having an RCA 9Y5. I've replaced quite few components inside but in the process, I suspect the selenium rectifier has failed - as in dropping voltage. The dial lamp now dims almost immediately after turning the power on. It used to remain at a constant brightness.
I have an assortment of diodes on hand but am unsure what amperage the diode should be. I think I'd be OK with an IN4005 - 600V 1A.
The RCA is an oldie from 1949. Researching selenium rectifiers makes me think an IN4005 - 600V 1A would be OK. But I am not 100% certain about the amperage
FWIW, this is the info stamped on the selenium rectifier that I think is toast.
