I've done a bunch before but always I removed the dust cap to shim the voice coils.
I'm thinking I might start to work on these old vifa 8" drivers that came with the Snell EII.
However, I am seeing these replaced without removing the dust caps. Looks like you can attach the surround to the cone first, allow to dry, then clip the surround to the basket and check for rubbing of the VC.
I suppose I can check for VC rubbing by hand, or even use some low frequency to get some travel.
Anyone ever do surround replacement without shimming the coil here?
