laatsch55 said:
Gibsonian said:
Looks like a good solution, and not many parts. As long as there are DC fans out there with enough airflow to keep the PL's cool at all times, it'd be a go. I use two DC fans that probably would not be enough to keep the 700 cool if I was continuously banging the needles to the right side of the meter.
I've got some DC fans that run the same RPM(or real close) as the AC fans. I thought it was a neat idea too, as I forget to plug in the fans before going to Mach 89 sometimes. After additional research the is an IC put out by Maxim that includes the heat sensor.
Me thinks so too Scott. Ya know we know nothing about the rest of your system, inquiring minds want to know.
Yes, I forgot one time, (actually alot more times but this on is memorable) and it was a bad time to do it (was seeing just how far I could crank it after sampling some coldies) as I took out some transistors and killed the amp that you now have in your possession Lee. I now leave them on all the time, safer that away. A heat controlled variable speed fan that is pretty quiet would be really good stuff.
