Power entry punch for 700B
anybody know where to get a Panel Punch the size for punching out the snap in IEC power entry connectors? I really don't want to use a blowtorch or a light saber. I had one in the lab I worked at when I was building test equipment. I used it on aluminum enclosures for the same thing. Worked great and it wasn't very expensive. It had 3 bolts you cranked on after drilling a centering hole.
If I can get one and anybody needs to use it, we can pass it around... No bogarting.... Puff puff pass, puff puff pass......
Quote from Joe....."Rectangular Greenlee punches are mucho expensive and there is no standard opening size called for by the various IEC inlet manufacturers."
