Greg
Should check the Bis, using the other resistor on the Lt side.
I would clean the back of the board w a tooth brush (and do a Visual inspect as you go)
and also clean the back and inspect everything after cleaning.
after that I would change out both Bias Transistors
looks like a Full comp amp (which sound better)
Whats your plans?
