PL400 WOPL starting to get parts together
Mholz
HI all I am going to start a Full comp PL400 WOPL and have some questions on any other materials I should get.
I am not sure if kit comes with enough wire to redo all wiring or just new boards so maybe some assorted 16 & 22 colors?
I’m curious if can get with kit. Fuse holders,fuses, speaker binding posts to name a few.
I have a 4 and 8 fin I just won on Ebay and should be here soon. 4 fin has lot bad and 8 is supposed to be working but will
test just to see
I’m still waiting for final estimate for kit so anything I should add in now would be appreciated
Thanks Mark
Someone here sells Teflon coated wire ideal for these builds. I don't remember their handle here but if you search, you'll find them because everyone uses that wire.
Hexis22
Wisconsin
Here is a typical BOM for one of my full 400 builds:
PL400 LED Light Board RevC
Warm WHITE
PL400 LED Light Board RevC Wire Harness and Sensitivity Switch
PL400 Capacitor Assembly
2 x 15,000 uF/100V/105C
PL400-700 Bus Bar Assembly Kit
PL400-700 Bridge Snubber Kit (50A/600V bridge rectifier included)
PL400 Backplane Kit
PL400-700 Backplane Wire Kit
PL400 Series1/Series 2 Chassis
PL14_20 RevG1 Dual Mono Control Board Kit
Unassembled Kit w/Phoenix Connector Option
Output Transistors
ON Semi MJ21195G X 8
- PNP OUTPUT (for full comp applications only)
ON Semi MJ21196G X 8
- NPN OUTPUT (for quasi and full comp applications)
SIL400 Bergquist SIL-PADs
Thermal Switch
XFMR Stainless Bolts and Isolators
Speaker Output DC Protect Board
RCA inputs X 2
RG316 Coax for RCA input
Wire for all non bakplane items (order from member @NavLinear)
10' of 16AWG, White, Black, Green, Blue
10' of 22AWG, Orange, Green, Blue, Grey, Red, White
Rubber Feet X 4
Cap cradle grommets
AGC Fuse Holders X3
AGC Fuses
