I have a really nice model 700 series II that's working great other than the LEDS. Basically they don't work. Me and member laatch55 have troubleshooted it quite a bit on AK...see thread here: http://www.audiokarma.org/forums/showthread.php?t=643045
I'm focused currently on getting the main board working 1st which is the one on the right that includes the rectifier diodes and the additional 470uf 25v cap on the back. This board has been fully recapped and all the diodes have been replaced. All 4 transistors have been checked to be good. Voltage inputs at the UAA170 ICs (pin 10) and the RC4558 opamp (pin 8) correctly read 13.4vdc and the input signal fluctuates as volume increases at the switch as well at the board input...the attenuator switch seems to be working as well by reducing the AC signal by about 10 fold when engaged.
So, I'm a bit stumped to know where to go from here. The amp is working wonderfully otherwise so it's just the displays that are non-functioning.
Maybe I have bad UAA170s or a bad RC4558...options for replacements if needed? Are the UAA170 on eBay ALL bad? There's a lot of RC4558 replacements but not sure what specs matter for a proper replacement. I'm physically about 15 minutes from mouser so that's obviously my preferred vendor
Is there a good option for replacing the LED bars if need be?
I've also verified all the resistors...
