PL 700B blows 5AGX fuses on one channel. Checked resistance ( only have volt ohmmeter for testing ) of all output transistors ( removed from unit to test ) which showed 4 ohms except 2 on blown channel which showed 0 ohms. I assumed the two 0 ohm transistors were bad, so replaced two with some 4 ohm ones from good channel. Powered on, had reduced, scratchy volume on “bad” channel fading to no volume, blown fuses and one “replaced” transistor now showing 0 ohms. Thinking control board bad, but don’t want to just start buying parts, ie board, output transistors. Can do some repairing, but not sophisticated testing. Ideas? Shop to repair my unit? Located SE PA. Thanks
