PL 700 II Power Transformer
Randall Daniels
Good morning/afternoon/evening folks, got a problem and hope someone can help.
I am in need of a PL700II Power Transformer.....yeah you heard correctly. The secondary side
measures 0.3 ohms red to black to red. Knew when I purchased it had a hard life.
Well, need some wisdom on replacing/rewinding on these puppies and figured this would
be the best place for it. Has bigger caps and WOPL pcb installed that worked great for
over a year...but now we are toastado......
P.S. yes I know how to work on electronics
How do you know the transformer is bad? That resistance seems too low for you?
Randall Daniels
Too many things going on at once......step away from the electronics and think(something pretty
hard to do with 2 little grandchildren running amock....)
Unless you're using a micro-ohmmeter, resistance readings only tell you it's not open. If the transformer winding(s) were shorted your nose would tell you it was bad. Verify the primary and secondary are not open and then use the dim bulb test set on the primary and read secondary voltage to confirm it's ok.
