Phones Phans, here is some 'Sui sound, sweet shape, sensible shekels...
I assume they are GONE at $14.95 unless the didn't sell (BIM) and come up again.
They have been relisted, same price.
I just report them, mister, I don't create the financing or polish the hubcaps.
Who is Elder Berry, and does he make decent wine?
I have a pair of those Sansui SS+2 headphones in the box, and a pair of Hitachi HD-66, also in the box. I bought them at the local mini flea market at about the same time. I should dig them out to listen to them again, but I'm sure they are not in the same league as my AKG K-240s.
62vauxhall
Southwest Kootenays BC
No, they're not. I too had some of those Sansui's also in the box and with manual/brochure and I donated them to a radio/electronics museum.
They also came from a 2nd hand store.
I happened to be standing at a shelf when a clerk put them out for sale right in front of me. She also put out a pair of AKG K141 Monitors (with the gold badge) and a pair of Fostex something or other. Price was $2 per pair so I bought them all.
Gary: The AKG K-141 Monitors were an extreme bargain if they worked OK.
62vauxhall
They work perfectly but got a replacement pair of pads and foam discs from Harman a couple of months ago. The reason was that I intend to give them to a friend to use if and when she ever digs out her stereo. The original pads were naked foam and would sometimes trap a hair or two and you know how distressing that can be!
I just checked and those Fostex are model T10. I did read up on them after I got them and the opinions were mixed but basically nothing to write home about. But during the brief listen I gave them, they sounded fine to me and they are comfortable like the K141 Monitors.
Agreed that $2 was a theft but the pair of K240 Monitor's (also with gold badge and in perfect condition) I got at from IA's garage sale last June for $5 was not too spendy either.
I've owned K240's before and they're my favorite - good bass and comfortable. The worst one's I ever had comfort wise were Koss PRO 4AA's and Koss /e9 electrostatics with the power supply. Both weighed a ton and my temples could take no more pressure after 30 minutes or so. Had some AKG 340 electrostatics once that didn't need outboard power but they were too big and awkward.
I like headphones I can fall asleep while wearing - kind of like you forget they're there. And, if you accidentally step on the cord and rip them off your head, they should be light enough to pull away easily and be undamaged when they hit the floor.
There's another set of "cans" (literally) I have stashed away as a future project - Toshiba HR-50's and writing this has just made me remember them. I got them free from where I cannot remember but it was a long time ago. It says "Cross Field" on them and I think they have some kind of dual elelment. There's a switch that turns that effect on and off but that switch is broken therefore the headphones don't work. I tried getting them apart once to fix the switch or bypass it but failed. I couldn't figure it out. Now that I recall having them, I'll dig them out, post some pics and perhaps one of the good people on this forum will have helpful hint. I'd like to hear what that "Cross Field" effect sounds like.
