HiAttached is the 3300 II Service Manual.
Is the hum heard in both channels?
and the tone switch does more hum when it 's onIs the hum heard in both channels?
Does this kit include new power supply capacitors ? If not, it may be the power supply is dirty. If its typical full wave rectification, the hum should be 100 hz. If its a ground loop problem it would be 50 (in Europe anyway). A scope check on the power supply output to check for ripple would tell it, but maybe try replacing the power supply capacitors if you don't have a scope and have not done it already.
HI
I have pull off the power supply kit and replace with the 2 capacitor and the bridge and it is a little more noisy and when i power off i can ear from 5 secondes the hum decrease slowly
i have record the noise but i dont know how to join on the forum
it is 08.25 on the morning in France what time is it where you live ?
Many thanks for your help
alain
Let's start over... what amp is this hooked to when you hear the hum?
Alain.....some ideas might be had by reading this thread....http://forums.phxaudiotape.com/showthread.php/5068-Brother-Lyle-s-Phase-Linear-3300-Ser-II-Preamp
