- Jan 14, 2011
- Gillette, Wyo.
Looks like no Zoebel at all....
View attachment 22699View attachment 22700
Left Image: New Jacks were too small for the original PL hole and insulator. So I devised a trick using a piece of cut off resistor lead wrapped around the threaded part of the jack.
Right Image: Rewired input section. The back to back diodes are gone and the PL ground to earth resistor scheme installed. Odd resistor values those are... 2.7 and 56 ohms??? How derived that one? I normally do 10 ohms from signal ground to earth ground.
Seems like I can only ad two images per post.
Yes, the Zobel is on the meter board.... I changed out the caps as they were only 100 volt caps.
That connection is on the control board. Those resistors between the signal ground and the speaker ground should not be there.
PM me your email address and I will email you the improved ground schematic.
View attachment 22701View attachment 22702
Left Image: I replaced all the emitter resistors with 1% tolerance.
Right Image: I noticed the positive regulator seems to be running quite a bit hotter then the negative regulator is. Is this normal? I can't quote any temperature specs yet but I will tomorrow. Positive regulator measures about 15.45 volts and the negative is about 15.12 volts. Offset is still very low down in the mv range.
I also only have 4 outputs in per channel at the moment. I need to go to the parts store tomorrow and pick up some new mica insulators. I can also get ceramic TO-3 insulators but I think I'll save those for when I take it full complimentary.
Mark
____________________________________________________________________________________________________________________________________
Email has been PM'd.
The resistors don't land on the speaker terminal ground. They land on the ground lug that's screwed to the chassis...
Mark
Even worse Mark. There should be one chassis to DC ground tie point and only one tie point. That connection should be from the bus connection between the bulk caps and the chassis.
Phase Linear used a variety of ways to illuminate the Honeywell VU meters used on later 700's. In the case of many of the amps with Honeywell meters, the Zoebel network is on the meter drive board (i.e. PL 7M or PL16A). There were (4) peanut sized bulbs (like the ones used on Phase 400's) used to illuminate the VU meters. The pc board was screwed to the bottom of the VU meters. The bulbs mounted through holes which were drilled out on the bottom of the meters. It appears that the bulbs in your amplifier have been replaced at one time with the same type of bulbs used on 700B's. Phase Linear also used fuse holders glued above and/or below the Honeywell VU meters with fuse style panel lamps to illuminate the meters. In this case, the Zoebel should be mounted on the speaker binding posts.
I would recommend re-locating the Zoebel network in your amplifier to the speaker binding posts.
Earlier Phase 700's used Argonne VU meters which had small bulbs internal to the VU meter. The Argonne VU meters are the best VU meters Phase Linear ever used. I have never seen one fail. The Honeywell's had a high failure rate much like the Midland's used on early 400's.
Ed
You should not run NTE devices in the bias position. We recommend On-Semi 2N5088's, installed in the same P-strap as the 3403's. Did this amp have a pl0171 board?
It did have the PLO-171 board.... I can order some 2N5088's... but comparing the two the NTE's have quite a bit higher operating voltage and current 75 volts vs. 30 volts for the 5088. The thermal tracking is actually pretty good too. The amp doesn't run nearly as hot as it used to without the devices mounted to the rear panel...
So whats the big difference between the NTE's and the 2N5088?
By the way... NO one seems to stock the On-Semi. It's either Central Semiconductor or Fairchild.
Mark
__________________________________ON Semi EOLed their entire TO-92 product line when their packager in Malaysia ceased business on TO-92s They did not want to find an alternative packaging house to continue this piece of their business. Perhaps that will change after their acquisition of Fairchild completes.
Mouser has about 125,000 of the Fairchild 2N5088 in stock. Plenty!!!
