Phase Linear 700 power switch
I get 2-3 emails a week from people looking for a power switch. does anybody have a source for either type that was used.? I am looking at options to use the switch to drive a relay or a triac.
The microswitch clusterfuck you wouldn't want would you?? The other's I think Ed had the only stash of those.
If you're looking at a single deck they can get pretty small, especially if it's a low current application.
Were these amps designed by Greg Kinear (sic)?
These would work except the knobs for most 700"s are a push on type with a "D" shaft. I've never been able to modify a round shaft into a D shaft and have it work and look right. Very labor intensive.
Broken car stereo donor perhaps?
P.L.F.
I love BIG amplifiers!
Got in touch with friend repairing McIntosh gears here (i.e. in Warsaw). He indicated one more option: http://www.analogmetric.com/goods.php?id=1164. Slightly less than 3/8'' but D-shaft type as a bonus ;-) ...
Don, a Dremel with a drum sanding attachment and in two minutes it can be DAMN close.
