Phase Linear 400 Meter needed
BlueCrab
I'm in need of a VU meter for my PL400 series 1 - 4 fin version. Lights are on the bottom. I'm willing to pay a reasonable price including shipment. Let me know if you have one you're willing to part with. Thanks!
BlueCrab
If the guts are good, I'm interested. Mine is cosmetically okay, but one of the previous owners dicked with it and stripped the pivot points. If it's the same type, it should fit. Makes a nice paper holder though.
nakdoc
Nashville, TN Music City
highly biased
Murphy's Oil Soap cleaned off the smoke, which came from the lamp holder rubber. This meter is a Dixon, Inc brand with the movement at the bottom. Bezel is 4.6" wide and 4.1 " tall. The housing has openings for 4 lamps. It works just fine.
