Osama yo Mama!
jbeckva said:
laatsch84 said:
lolololol since my smilies still don't work :joker:
Ok, let's try something here...
Question for ya... when you reply to a post, are you using the "Quick Reply" or are you actually clicking the "Full Editor" next to the "Submit" button? Clicking the "Full Editor" button should bring up a list of smileys (like I am seeing now to the left of this "box")...
Lemme know.. "I'll fix yer wagon, I will, Lil Missy..." :mrgreen:
So when I go to full edit, it still does the same thing...so I don't know... nothing is disabled and I did as Lee suggested and turned off the pop-up blocker for the sight but still nothing... sometimes it works sometimes it doesn't posting.php?mode=quote&f=4&p=8639#" onclick="window.open(this.href);return false;
Log out and clear your Phoenix cookies and then log in again and see if that helps. :) Or try a different computer so you can narrow it down to either computer or the forum settings.
