Nando's Prog-rock Mix Tape
BlazeES
OK, so I promised to keep quiet about the "set" but I'm compelled to get going on my initial impressions with respect to performance:
First off, Nando's tape sounds absolutely freaking amazing on my ES rigs! :p (and this is after a run through only using my cans; I've come to the realization now that if a recording sounds mind-blowing on cans that it will sound killer open air...) I've received many a mix tape from associates but never have I auditioned one produced on an Esoteric deck, so this mix tape experience is multifaceted to say the least. What a treat!
Nando used Dolby C and it tracks perfectly. I'm almost speechless how outstanding this recording is from a fidelity standpoint. Nando used a Sony XR and this is the second
XR mix tape I've received; JaeTee sent me a phenomenal DJ inspired compilation over the Christmas holidays that sounded very good as well.
These tapes are beyond description and damn near replicate what Metal Masters
can do at a fraction of the cost. I'm sold!
It appears Nando kept the levels lower than what most folks would tend to do and it didn't matter one iota; gain, dynamics, noise-floor, channel separation and spacial presence are all solid at levels averaging between
0 and barely eclipsing 2 dB. This speaks volumes about the head-block and channel circuitry in that beast of a deck. I've always been pleased how well my various ES rigs would track tapes made by other people's decks but there seems to be some type of mystical marriage between Esoteric and Sony. Or I'm stoned. :toothy10:
Incidentally, I've backed off recording with peaks pushing the limit lines for several years now and have realized that leaving
room for dynamics is "key". Nando's approach only goes to further my new found beliefs..
Today my stack is configured TC-K870ES with only a CD Direct input connected so I auditioned through the on-board headphone jack.
My TC-K950ES is looped through my processor to my Maverick tube headphone amp.
On the TC-K870ES the tape sounded so damn spot-on I thought it was a tape I made myself. Phenomenal!
On the TC-K950ES set up the tape sounded almost vinyl like, warm and vibrant. Since I am well acquainted with the
Side A's first track, critical listening was easy simply due to familiarity with every subtle nuance of the song at hand;
one of my all-time favorite acoustic prog-rock tunes btw! :glasses8:
Thanks Nando!!!!
(more to come...)
VintageShadow
Transylvania
Obviously lower levels are the best and the sounding is better and detailed having air in it, higher levels gives the impression of everything compressed kind of loudness war on tape. BTW, i do have a mixtape from Nando recorded on Sony HF with Dolby C and it does sound stunning. :thumbright:
Miracle Mile
Nando's tape sounds absolutely freaking amazing on my ES rigs! (and this is after a run through only using my cans; I've come to the realization now that if a recording sounds mind-blowing on cans that it will sound killer open air...) I've received many a mix tape from associates but never have I auditioned one produced on an Esoteric deck, so this mix tape experience is multifaceted to say the least. What a treat!
Nando's tapes are always a treat......
BubbaH
That V9000 has to be one of the most well received decks around. Tapes Nando has made on it seem to sound good all over the world. Even my KX-800 as fussy as it is, seems to jive well with the Eso. Nando's tapes or some of the best productions ive received.
Thank you Tony, and all, for your kind comments. Once Jerry receives his copy, I will share more about this mix. I sent Jerry a track list document with his tape, and I will post the document for you and Miles as an item of interest. Progressive Rock recorded to a C-60 is tough, as it's a squeeze to fit long tracks onto such a tape.
There are a few more great mix-tapers who have recently joined our forum. It's probably one of my biggest highlights in being an active member, as it's good to share with all my friends. The world doesn't seem to be as large a place as one would think, when you can share music in this age-old fashion of cassette mixed recordings.
BlazeES
I agree Dracula! :evil1: And would only add that some decks handle level "push" better than others not to mention that finding the balance between recording TOO low and hitting the wall, so-to-speak, is half the fun of doing analog. Most manuals direct users to achieve the highest possible recording level, just south of perceivable distortion but we all know that tapes & decks spec out better down at -20 dB.
So therein lies the challenge..
Honestly, I've never done much experimentation recording on quality metal tape, more centered around -say - 0 dB, but Nando has prompted me to try different things now..
Much more interesting than bemoaning eBoy hassles to no end..
VintageShadow
Transylvania
Yehhehe :evil1:, from my own experience i'm always recording with quite lower levels, to speak so +1 with regular ferrics and +2,+3 max peaks for dopped type'sII, now using HX-PRO for example i noticed it's not a problem to reach +3 max peaks with ferrics and they still sound very good, another little secret[maybe] and it works for me so i'm lowering the rec levels on the deck and i'm raising the output signal gaining this way some more headroom extension, it seems the hiss level is much lower this way if no N.R. is used, yeah, it's so much fun to see how good can sound that little cassette cutie :cool:
jaetee
Nando is definitely a Mix Tape Master...
I'm actually sitting here listening to his "Even Roses Have Thorns" compilation recorded on an interesting Sony GIG-1 tape. Sounds fantastic!
Thanks for the honorable mention in your write-up, Tony! :)
John: You, Robert, and I had a great mix tape exchange with the Valentine`s Day tribute. I learned a lot from all the members I have exchanged mix tapes with. And I have more to learn and attempt... as long as one of my decks doesn`t crap out. I love seeing your Dragon in action. A friend of mine, Robert, has offered me his Nakamichi 682 ZX for an unheard of price, when I dropped in to visit him, yesterday. I will post pictures of his system, later.
Dazen1
UK
I think I first exchanged a mix tape with Nando back in 2010 and it was pretty clear that the guy knew what he was doing.
As for that Esoteric deck - definitely a wolf in sheep's clothing. Looks good too.
Thank you, Daren. We have had a good run of tape exchanges between us. You may not have a cassette deck at this time but that hasn't deterred you from still being involved in some way with analog tape.
BlazeES
Prog-Rock Mix 4 Nando
A bit late in coming but hopefully worth it! Blurred to protect the content.
Come to think of it, that rotational "in-motion" blur effect does complete justice to this tape.
Looking at it more I should have made up some BS story about how it will start to move like that, all possessed like, if you don't pay it any attention by actually playing it.
And how I found it inside my deck one morning, all powered up and ready to be recorded on, with some lesser tape I had originally chosen clear across the room - busted into pieces. :evil4:
LOL
I've since tucked the linear details inside the J-card Nando to keep things suspenseful.
Listen first, read later! :evil4:
Side A - Sonic Interlude
Side B - Sonic Mayhem
For those curious, it's a Maxell MX C-90.
A sleeper formulation.
Thank you, Tony. Don't even fret about the time between our exchanges. I appreciate the gift of time, creativity, and effort in what many of the members contribute to mixes I receive. I can't be as quick as I would like to be on many occasions, either. It sounds like I have something intriguing heading my way. Whoa... a Maxell MX mix tape - I haven't received one of those in a few years.
