Nak RX-202
speakerman1
OZONE ALLEY MARS (Visitor)
Wasted Days and Wasted Nights
Someone wanted to see it. Next to the LX-3 it is a very good 2 head. I wanted on since I saw one in 78. Neater than sliced bread. I have even opened it up. Have to today and Deox the motors and lube some thing. Will check belts. If bad I will get them and put them on since I will be there any way.
Larry
speakerman1 said:
Here are the nudes, There is one scratch on top. Belt is good. About to circuit wash the boards. Do you want to see the Daqarta program set the speed or check it?
Larry
That would be neat to see how it's done, Larry. My RX-505 hasn't been used in over a year, but you got me thinking about putting it back into service.
speakerman1
OK this is the Daqarta freq meter. This deck is running a little fast I guess. Don't really have a manual to set it. LOL The tape is left channel in @ 3000 HZ. You can also get your millivolts.
Larry
speakerman1
Yes deck 0.00 shipping 150.00. LOL I'll set the speed in a bit.. That isn't all I have done on the deqarta.. Then clean,and demag.
Larry
stuwee
Deep in the Sonoran Desert SW
I never cared much for those flippers, mainly because I don't like azumith errors, which you will always get on auto-reverse decks, and IIRC you can still get slight errors with those flipper Naks, to me they are a novelty to impress your buds with, nothing wrong with that :rabbit:
