NAD 6300
Yep. It really is that bad.
I scrubbed the tape path enough to test it:
I had to polish the capstan shafts- they were rusty too. But what’s that yellow stuff on the heads? It’s not coming off with a lot of alcohol scrubbing.
But, it actually works!
Tape door is rubbing The right side of the face plate. Nothing obviously wrong so I’m pulling the transport out either way. There are connectors for the transport, but it is cross screwed in all different directions, and not coming out easily.
The corrosion on parts of the tape transport is worrisome. I hope you can successfully clean it up. Did you play it through a system to hear how it does, as it has no headphone jack.
Yes, I was in with my headphone amp and headphones. Sounds fine.
Play fast forward rewind pause all work fine.
Rust on the capstans was more of a concern for me, but since they run all the time I was able to polish them up with a piece of Cratex stick. The supports I’ll clean up when I get the transport out of the box.
I’ve got some rusty Springs and other bits in there to clean up too, but I’ll take care of it.
Any ideas what’s on the heads? Do we think acetone is OK to use to clean it?
I want to see this deck work for you, as it's certainly a survivor. Try acetone first then play an unused true chrome BASF cassette through the deck a few times.
I don’t have any true chrome tapes. I don’t think so anyway…
despite the deposits, it sounds fine. The Oz Noy tape I played I know well and with NR off it sounds like it should to me.
Perhaps ignoring the problem is the right answer…
It feels like there’s another screw holding the bottom of the transport but I can’t see anything yet… maybe now that the divorce is complete. (Not service friendly)
by the way: the service manual only shows how to do the electrical alignment/bias/gain and has NOTHING on mechanical.
I put the back plate back on so I don’t lose those screws at least…
Ronnie_B
If you still have rust to remove use Evapo Rust. It dissolves rust without etching the metal underneath. I've used it on reloading dies, etc that were rusted and all brown rust disappears overnight. It is sold in liquid and gel form, gel would probably work well using Q-tips to apply on problem areas. Clean up with water.
No glue. Another screw was found once I had the face away from the unit. These were not cheap to build; I wouldn’t be surprised to find out that NAD lost money selling these.
With it out, it seems straightforward. Uploading a short video now- capstan end float seems excessive (and I have no specs in the service manual)
Maybe it is pulled against the thrust pad/bushing/jewel (whatever is there) by the magnet to keep it in line?
I'm not tearing it down further until I have my belt kit in hand.
Back to cleaning, and re-attaching the meter "glass" which fell out of the face... no idea where my Barge cement is now... I'm going to clean the pots and switches as well since it's open. Just the slightest scratchiness from the "play trim" pot when I was messing with it.
