The 1300 is a well-regarded preamp in stock trim. however, it's rather upgrade-friendly with a standard OpAmp (collection) for amplification. Nine of them in fact.
And they're crappy (by today's standards) NJM 2043's. We will replace these with Ti LM4562 OpAmps. Every published parameter is better, but noteable is CMRR at 120dB V 100dB; Slew rate of 20v/mS v 6v/mS. They are clean, fast and quiet. Pinout is the same, but supply voltage is a bit lower. I'm installing sockets while I'm doing the job in the unlikely event a better OpAmp is developed in my lifetime.
To do this, a couple Zener Diodes have to be changed from 20V to 17V. I'm replacing the power supply caps with higher voltage Panasonic electrolytics while I'm in the area. I'm not doing a full recap as it's unnecessary, and I want to study the schematic (attached) further and decide where I can use films in any audio areas. Plus, it's generally a good idea to limit the number of changes you make between testing; in case you screw something up...
Basically, taking a perfectly good preamp, and cutting it up.
