yesDidn't Phase Linear use the 15024/25 in their fully comp amplifiers?
True, not a rumor. Look at how weak and underspecified this device was that got used...A rumor I heard:
The first PL amps used the same NPNs that GM used in their electronic ignitions.
Is this a conspiracy theory you are hatching Glen?So to poke the bear. I believe the new runs of mj15024/25 are rebranded 95/96’s and are identical. If you look at new pricing they are also identical on most sites. I got get some and cut them open to see. Spec for both attached
Well it seams to be the trend these days if you look at the news. Just wanted to get people off their easy chair.lolIs this a conspiracy theory you are hatching Glen?![]()
GET A PROTECTION RELAY FOR THAT THING! NOW!I have a stock 400 8 finner I bought brand new in the mid 70's that I used when I used to DJ. I still have it and it is 100% all original with the xpl909's. It still plays just as good as the day I bought it
Yeh…. Those were baaad!True, not a rumor. Look at how weak and underspecified this device was that got used...
GET A PROTECTION RELAY FOR T MJ4XX THING! NOW!
I fuse the speakersGET A PROTECTION RELAY FOR THAT THING! NOW!
