- Jan 14, 2011
- Gillette, Wyo.
Had a lot of problems with the Neu-t-Rol chuck controller. So I built a +/- 117 VDC power supply , with the only de-mag option is to reverse polarity manually., What has me stumped is this little paragraph in the controller manual------------
Breaking the D.C. supply either ahead of the Neu-t-rol and the Magnetic
Chuck, while the Neu-t-rol is in the full "on" posit ion by other means
than the Neu-t-rol is dangerous to the Magnetic Chuck and should never
be attempted. This practice surges the Chuck with the possibility of
puncturing the insulation and causing grounded Chucks, which can also
break down the insulation on the Neu-t-rol drive motor and burn out an
excessive amount of pilot light.
Being the voltage and current will be coming right off the power supply with no intervening components I could see a surge. Not talkin a whole lot of either, 230 VDC at 2.97 amps...
Sooooo.....how do I control the surge?
