Let's talk caps...
jbeckva
Admin/Server Dude MAA Guy
WassupYa Mang?
First question I have posed to the audio tech gurus... Silver Mica Caps - anything special about them? I need a few 750pF for use in a crossover to rebuild - can't quite get the value I want out of Parts Express for their metal polys they have.
jbeckva
WassupYa Mang?
Put in context.. here is the xover schematic.. (might recognize this one eh?). The silver micas are being used in a bypass type of configuration, right? Isn't there perhaps some sort of consolidation I could be doing here, that also would have the values needed actually be values that solen and the other audio metal poly's come in?
Silver mica caps are right on top of my list Jer. Extremely temperature stable, excellent dielectric, usually very precise and are usually very high voltage (again that great dielectric).
I use them on all the small value cap locations, excellent sound qualities. The military used them for all these great qualities.
The silver mica values are not critical to this application Jer. They are there to offset the small inductance of the mylar caps at higher frequencies. The values of the Mylar caps are critical to the behavior of your crossover.
I have a dozen 140,000 uf at 20 volt caps in the garage that I vaporise screwdrivers with. Sometimes all the caps make and sometimes they don't.
