Lee's Spec 2 Unit # 1
My...
But the clipping at 280 watts thing...muy amazing compared to the Pio's in MY universe.
So are you finding some legit caps?
Yep, got some here in stock.
Counterfit components are a serious problem - sorry to hear about your situation.
Why am I suprised - you just happen to have some 22,000 uf 100 V caps sitting around - maybe you don't need a real work bench. You wouldn't be able to find anything!
I seem to operate poretty well in a semi-chaotic environment. Ten minutes after the power supply project, the bench is as clean as it usually gets. AND Cap stashes. the ones on the speaker are enduring Joe's recommended "forming" to go in the Spec tomorrow.
