Leave your amps outside much?
gadget73
Whats the proper heat sink for the Series II ? The one I worked on looked similar, but all of the fins were the same length. My Pro 700 has the same equal-length fins.
The 400 Series II's had the same as the later Series I's. The two inner were shorter than the two outer for each channel. All 700's had the same design heatsinks, except the Series I's had a different pattern for the outputs and will not interchange..
