- Jan 14, 2011
- Gillette, Wyo.
The following is a copy of Joe's post on the subject.
Here is what I did to achieve this.
1. Removed the white 22AWG chassis ground wire that runs from the copper bus pad between the input RCA jacks to the White Oak PL14_20 PCB, pin 5R.
2. Removed the 16AWG bus wire jumper that Phase normally installs between this same copper bus pad and the right channel speaker ground binding post.
3. I left the 2 signal grounds in the signal twisted pairs that originate at this copper bus pad between the input RCA jacks that run to the White Oak PL14_20 pin 2R and 2L respectively.
4. I added an 18AWG tinned solid copper bus wire jumper between the right and left channel ground (black) speaker binding posts.
5. I added a #10 ring lug with 2 white 20AWG wired into the ring lug on one end and into the White Oak PL14_20 PCB pin 5R and 5L respectively. The #10 ring lug was attached under one of the large bulk capacitor ground bus bar screws that connect the 2 bulk caps together.
6. I changed R2L from 56 ohms to 2.7 ohms.
This makes the large ground bus bar between the 2 bulk caps into the Single Point Ground for the entire amplifier. This wiring scheme eliminates the common mode noise from the large speaker ground from entering and affecting the low level input and low level ground reference on the White Oak PL14_20 PCB (caused by the bus wire jumper that Phase Linear installed between the right speaker negative binding post and the copper pad at the input RCA jacks)
Hope this is clear what I did. I will try to document in a diagram later on.
