- Jan 14, 2011
- Gillette, Wyo.
And there is no cure for that...
Magnetostriction. I like that word. You know as I walk the dog around the block tonight and evermore that words going to be on my mind as I pass those transformers.
Thinking next time I have the transformers off the amps I'll most probably add non-conductive epoxy as a precaution. I have some small syringes for injecting DeOxit into switches and pots. I'll look for some large ones capable of handling epoxy. Be nice to put it where it counts.
I'm off to walk the dog and listen to magnetostriction. Later.
Will you be selling a kit?Keystone 3058, perfect! You'll need to shorten the bolts a little to keep them from hitting the storage caps.
Joe should bundle a little add on kit for the 400 with these, bridge rectifier board Capacitor mounts and terminal strip. All costly to buy one off from mouserDon't think so, too damn busy doing other things. If Joe wants to offer them that's cool with me.
A 400 and 700 insulated bolt kit would be a good addition to his offerings.
Not a silly question at all. Here in the USA, all metallic electrical equipment is required to have a solid Earth Ground.Silly question : here in Europe the metallic parts (chassis) have to be connected to earth. If I understand correctly the transformer assembly described here, it will be isolated from the chassis, and so not connected to earth. Am I wrong ?
