- Jun 12, 2010
- OZONE ALLEY MARS (Visitor)
- Wasted Days and Wasted Nights
Don't know about monsters. Most everything in base components has been altered in some form or is in the planning stages for an upgrade. The humble abode or adobe you choose. They are going to insulate the garage door also. Wrap the skylight tunnel. I ordered one piece of base trim and corner pieces. I think I think it is to wide. The corner pieces can be cut down.
Found this place in my travels. http://www.audimutesoundproofing.com/acoustic-baffle-ceiling-baffles.aspx
