- May 14, 2014
- Southwest Kootenays BC
FWIW, I thought I'd post this in case anyone else has a thing for old turntables and changers. The Garrard Zero 100 I've had for a few weeks now has been working splendidly since I got all the old gunk out of the mechanism but the platter mat was an eyesore. The rubber is quite thin and was extremely well glued to the metal so I was concerned about tearing it while trying to take it off. Last night, using my (what has turned out to be an unbelievably useful tool for many things) Richard Roofing Knife, I worked it underneath the mat, gently prying it away and it came off without any damage.
I read quite a few posts on various forums looking for suggestions on how to restore black platter mats back to black. Mine was kind of 50 shades of grey. Several treatments were recommended including using a liquid which one would use to restore belts and things. One of the products named was MG Chemicals Rubber Renue and I just happened to have some. So once I had the mat off, washed in warm soapy water and dried, I gave it a go. The cloth I used to apply it was blackened very quickly by the presumably oxidized rubber that was coming off. After letting it sit overnight, it is now looking quite spiffy and all one shade of black. Wished I'd taken a "before" shot to illustrate the difference.
Side note: Although they're probably harmful, I thought the fumes smelled lovely.
