How a stereo cartridge works
Makymak
Well, when I was a kid and started to understand the stereo audio, I was curious how a single
needle can transfer two signals. I was a rookie (and still I am) and some pathetic maths like
L+R or L-R didn't meant anything to me... Ah, my youth...
Anyway, maths can't be heard but I was listening to the damn real thing! Yes, there were two
channels. I was freaked. WHERE IS THE SECOND NEEDLE?????
The groove has two walls so it can carry two signals; each one on every side. But how can these
signals be transferred using only one medium? The big bang in my head did happened when I
studied how a single wire can transfer multiple analog signals. It all depends on the point of
reference. WHAT???
Oh, yes.... The needle is one but it can be moved in different ways depending where the point
of reference is. So, the needle can be moved simultaneously in two ways, each direction
corresponding to one channel.
The above schematic shows a basic construction of an MM cart. It shows the stylus with the
magnet, the coils and the groove. Well, it's not state of the art but it can be used to our
purposes, here.
We take a signal on the right channel (marked with red color). This wave pushes the needle
not directly up and down but in an angle of 45° from the vertical axis. This results in the magnet
moving to the opposite direction but on the same plane of the 45°. On the back side of the
cart rest the two coils. Each one for every channel. They are placed with their gaps facing the
magnet in 45° from vertical axis and 90° from each other. Now, HERE IS THE MAGIC!!!
And the magic obeys to Faraday's law. The magnet moving from one pole of the coil's gap
to the other, produces emf (electromotive force). In simple words, it makes current flow through
the coil. The magnet moving vertical to the coil's gap (meaning that everytime it's distance
between both gap's poles is always equal) produces theoretically zero emf. Practically, for
technical reasons always some current is induced and this is the reason LP format has quite
poor channel separation.
In the drawing above, we can see a right channel signal. The opposite happens for a left
channel signal. A mixed movement represents a stereo signal.
Do you want more? The above configuration actually works flawless for the old mono records.
Indeed, a mono signal can move the needle only vertically inducing the same current in both
coils, so a perfect backwards compatibility. Clever?
PS. The above are not meant to substitute an advanced knowledge. The above are referring
to people like me who want to gain elementary knowledge.
PS No2. Not being a smart ass. Just my little contribution to the forum. I know novice people
are curious about the subject, just like I was.
I hope you'll find it useful.
Maky
want to just say that, being stereo vinyl groove system quite particular, it's not possible to keep the two channels totally indipendent... then, for example, bass frequencies on stereo vinyl must be mono otherwise the needle will jump out of the groove.
the "non in phase" (=stereo) signals can only be allowed on certain frequency ranges.
nevertheless, it can sound awesome even with such limitations, which is part of the magic of vinyl.
There is also a needle that will play the positive grooves. It has a ^ cut in it to allow it to trace the stampers.
It automatically plays the song backwards, to get the secret devil messages.
LOL!
during my teen years back in the 80s, I used to backwards play Led Zeppelin's "Stairway To Heaven" in search of the devil messages that they told they were into that song... the only one I've found was by playing around the line "there's a feeling I get..." backwards and, with some imagination, you could sort of hear "I've got to live for Satan"... but they say there were more messages into that song. o_O:p
another famous one was the "number nine" on Beatles' Revolution 9.
that said, on first album by the USA band Christian Death (Only Theater of Pain), the last track is a prayer recorded backards but, in this case, when listening to the song the right way, you hear just a backwards voice so it wasn't really a hidden message.
The Bi-Point Stylus is used to play a stamper to verify it will make records correctly. One that tracks at higher force, 7 grams or so is used when they need to 'tune up' the peaks and remove noises or issues that would make a record skip by slightly reforming the metal.
