Hi gents. I just packaged up the Rev-B boards into the new chassis and did some in depth testing.
I hope you all like the look.
You can build it as a kit, purchase the subassemblies as you like. Or...purchase built and tested boards, or the entire plug and play fully tested preamp. Send me a private message if you have any interest in this.
I just fine-tuned the RIAA PHONO Curve...extended response down to 3Hz. Phono preamp is DC coupled. Attached pic is the P-Spice simulation, compared to the original Phase Linear PL-2000. My version is exact match to within 0.2 dB total with more "punch" at 3 to 10Hz, below the 20Hz RIAA Spec for +20 dB. You will feel it!
Attached are some pics for you all to look at. It has the ambience rear channels and the separate tone and turnover frequency controls.
Personally...I love it❣
