Fuses........
ksrigg
Wise, Virginia
I am trying to find backup replacement fuses for the RSD 800b and they use an unusual fuse...the "T" fuse....It is small in diameter and in length, and I can't find them at Mouser, not knowing more than the designation on the fuse itself which is T 8 A 250 volts...2 for each channel, and a T 12.5A 250 volt for the supply fuse. The front of the amp is printed with T 8 A for every fuse, but it does make some sense using a higher value supply fuse, as the Phase Linears all do this. Can someone help me find this part number from Mouser? I only need them in case one blows, so I am good now. I just wanted to have a set in case I had one blow...
Maybe these fuses are a British or European thing, and don't know if I've ever seen one. I've seen way smaller ones inside CDP's and such and the short ones for the PL's but not run across this size before..
Thanks a bunch.
They are probably the 5mm x 20mm fuse standard Sutton. Measure them. 5x20 is a very common metric size and readily available.
