Recapped, switches/pots serviced tested, Some switches replaced, sounds excellent. The PO already changed the RCA's and added an IEC Power Socket. The lucky buyer will have the opportunity of having the White Oak Audio 4000t/C-4000 RCA plate kit installed for free by me while I document the install, or if you are up to the task, I'll supply you with the new plates/RCA Jacks but the 4000t can be a daunting task and one ooops, and you'll need another parts unit. With me installing the kit, you'll get a free $250 plus upgrade which is labor intensive for sure. Labor alone would end up at about 20 hours and possibly more. Total disassembly of a 4000t is a bear. Pics coming later.
Carver 4000t Freshly serviced $550
