Footers for the laptop??
stuwee
Deep in the Sonoran Desert SW
I read on another forum that heat will kill a laptop fast, should I get some hockey pucks for the Dell?? It does seem to get warm after some use of a few hours...
jbeckva
Admin/Server Dude MAA Guy
WassupYa Mang?
Make sure the air duct isn't blocked. At least with my wife's laptop, I have to go in there periodically with a vacuum hose and suck the dustbunnies out. Get's pretty bad - it can form an entire block just like a filter.
stuwee
Well I just took a peek-a-boo, very clean..I blew it and it smiled :D , you'd think out here in the desert lot's of dust and stuff... it still feels hot right now, my hand on the battery case just under the Shift key is to hot to touch for very long.
Should I put footers and a fan on it?
stuwee
jbeckva said:
Is it on a desk or lying on the bed, etc? I'd take the battery out and see if that helps any.. might need a new one. Beware of power outages tho, of course.
What??? Hmmmmm, you know a site for a good new batt??
It's on a nice wicker 1940's stand, lot's of airflow underneath...
speakerman1 said:
Stuwee
I run 2 fans on mine. They are pretty cheap. Plus mine also has 4 more USB ports. They just go under the laptop.
Larry
I can hear the fans run in mine all the time. Seems to need a hard surface to circulate well.
