D-500 dual
charkmapman
New to forum. Looking to have D-500 Dual restored. Have a 400 that needs resto also. Recommendations. Full resto. Done right. Thanks.
grapplesaw
Vancouver
I am now building a dual 500 with one of Joe's dual mono boards. It will also have be full complemtary setup ans many other little changes. May install a soft start and suspension mount the transformer.
Here are some shots of the rev E control board installed with two 33,000 uf power capacitors
62vauxhall
Southwest Kootenays BC
Some serious mojo there Glen.
Your build underway, 33,000uF caps seem like a lot even for a D500. Were caps that size, that physically fit, easy to find?
Is the xformer in those same as 700’s or larger?
grapplesaw
Vancouver
So yes it is overkill. And yes it requires slow blow main fuse.
They are the same size as the stock ones Gary. I got 6 sets for a good price and that is the only reason I got them for my system. As Lee says “Head Room Baby”!!!! And I guess if you are maxed out then you may get a further millisecond before distortion sets in
