Hello, I decided to recap the preamp myself. I have a question, and I would be extremely grateful if someone could answer, please.
I am following the schematics that I downloaded, and I noticed that at least on the Tone and Bandpass boards, some of the installed capacitor values do not correspond to the ones in the schematics. The installed ones seem to be 10x lower. Ex 2.2 uF installed 22 on the schematics, 10 installed 100 on the schematics. What rule should I follow: replace the same values as the installed ones, or match the one on the schematic?
I purchased a kit from Ebay from Hi-Fi-Audio-rocks, and the capacitors match the schematics, not the mounted ones. His advice was: "I would stick to schematic! I would stick to schematic!It is common for assemblymen to make mistakes."
It seems too much of a coincidence. I recapped a Phase Linear amp last year, and I did not have the same issue.
Thank you so much!
Thank you so much!
