I started building this enclosure today. Parts were CNC cut out of 3/8 MDO.
Ventilated top is. 040 brushed aluminum that I cut out.
There are dados on the back where a 3mm sheet of ACM with a cooling fan mounted on it will slide in from the side. Air will blow in past the heat sinks and out the top.
Aluminum feet are on order.
This will be my first time using wood veneer, any tips?
Also what kind of power is coming out of the fan plug in the back of the amp?
