BOSE 901 Series VI weird dilemma!
Puerto Rico
Folks, I got these 901 speakers from a friend of mine with the tulip stands and the active eq. The speakers looks new, with all surroundings intact but suddenly the left speaker start sounding awful and distorted. I checked the speakers but there's not much to check: no crossover, only drivers and wires. The thing is that when I turn the speaker upside down it starts sounding ok again! Could it be a loose connection?
Even at BOSE never heard about it!
El Magnifico
Recap the active eq, they go bad. Sounds like one of the speaker connectors attached tot he individual drivers might be loose if you flip it over and it sounds ok???
BubbaH
When I foamed the drivers in my series V's I soldered all the connections on the drivers. They come wound.
My brother has VI's and one of the cabs for sure has a bad driver in it. Just sayin.
Puerto Rico
The EQ is perfect. The problem is the speaker and it's not the binding post. I'm suspecting it is a bad driver... My Carver has a "external processor" loop. That's where the eq is connected to. In or Out, the speaker behaves the same. Eventually, it must be recapped though.
